15 years agoSOPC Building Error
Hy All , I am building a simple LED test pattern from "Board diagnostics" and selecting my own system (created my SOPC builder in Quartus II). After that I go to the "system library properties...
15 years agoHello,
I know this error in Nios that's y i told u if u have enough programming memory then and then u will be able to run. Anyway,you can not run this code with on chip memory.And if u unchecked "small C library" then u will not be able to use those functions. In quartus ,u got that error only because u increase your on chip memory.Try to reduce it till it wont get an error. And yes,Think another way for nios II but that way wouldn't work.Hope you understood .
