17 years agoSOPC builder system
Hi all, I am new to cyclone 2. I have a device EP2C20F484C7. I am able to configure the device using C2_Starter_NIOS.sof, ep2c20.sof etc but debugging and running the 'Count Binary' application ...
17 years ago --- Quote Start --- Reading System ID at address 0x01211158: does not match ID value does not match: read 0xDBDBDBDB; expected 0x6416665B Timestamp value does not match: image on board is older than expected Read timestamp 7:24:35 1950/10/15; expected 15:24:13 2006/04/21 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. --- Quote End --- Hi, if you have changed your SOPC system then *.ptf file will change in that case you need to create new project in NIOSII IDE and give path to new *.ptf file. Also make sure that your ram connection is correct in SOPC system. HTH -- SVaghela http://images.elektroda.net/92_1249971875.jpg
