16 years agoSlow frame rate (DE1 + D5M)
I connected the d5m camera to the de1 board and loaded the DE1_D5M project. When I plug the vga connector I can see images, but with a very slow rate. If I increase it (sw0 + key1) the image quickly ...
11 years ago --- Quote Start --- You need just increase the PIXCLK by adjusting the d5m build-in PLL, or connect XCLKIN pin directly to your in-fpga PLL. In terasic examples XCLKIN is set to 12MHz thru d5m's PLL, but PIXCLK has the same frequency(because of wrong config(I2C_CCD_Config.v)) Example of PLL configuration is in THDB-D5M_Hardware specification.pdf (pages 30-32) --- Quote End --- Thank you, I modify these two lines in I2C_CCD_Config.v following your help and it works 11 : LUT_DATA <= 24'h116004; // PLL_m_Factor<<8+PLL_n_Divider 12 : LUT_DATA <= 24'h120004; // PLL_p1_Divider Pixel_clock = 60hex(96decimal) * XCLK(25MHz) / [M(4+1) *N (4+1) = 96MHz also change the XCLK to camera module to 25MHz. refer to camera hardware specification in PLL (page 34) for more information.
