ABola2
7 years agosingle bit error in 7 bits ECC not detected, cyclone V FPGA.
i have checked single bit ECC error detection and correction in SRAM IP.
Getting error during write into memory {via encoder logic} and detection shall happen on the read from memory {via decoder logic}.
By injecting single bit error on 7 bit ECC and read the data, i do not see single bit error getting detected.
1 Reply
- FawazJ_Altera
Please make sure there is no timing violations. there might be some rare cases where there is a corrupted memory location that might cause this issue.
thank you
