15 years agoSimpleSocketServer problem on Arria GX dev kit
Hi I am a beginner in working with Altera FPGA's. I am working on a project in which i am using the Arria II GX FPGA Development Kit (http://www.altera.com/products/devkits/altera/kit-aiigx-pci...
15 years agoHi I'm trying to do the same thing but im not having the same luck.
which .sof file did you program into the board? I used the bts .sof that came with the kit files. Did you have to modify anything in the simple socket project in order to get it to work on the Arria II gx board? In the command sheel when I type telnet <ip address> 30 it tells my it doesnt recognize the telnet command. also when i do as you do and give it a random number as my serial number, i get back 0.0.0.0 as my ip address. Is that what you got? Thank for the help mike
