14 years ago
Simple game using Max II starter kit
Hi!
I really need help to the expert since I am not really familiar with Max II and verilog programming. This would be our final project for this semester.
The game is called "catch the L.E.D". :) so here's the scenario of the game. We are task to program the kit so that the 4 led will lit randomly and the player should press the buttons accordingly as the led "ON" state. If the user/player presses with timing OR able to catch the flashing LED, we will display his/her score on 7-segment display. The highest score will be 99. it has also a time limit of 1minute.
since Max II dev kit has 4-digit 7-segment display, we will display the time limit and score 2-digits each.
Max II development kit:
http://admucoe.tripod.com/max2.bmp
    sir, ovro.
    I have quick question for you. i have running code below which I used switch as input. but i don't have any idea how to implement button debouncing.
    code:
    --- Quote Start ---
    /*game pattern(LED | BUTTON)*/
    if(ButtonT==11000000) //button detection delay
    begin
    ledBlink = timer1;
    ButtonT = 1;
    if(ledBlink == 1)
    begin
    LED = D1;
    if(sw1==0 && sw4==0)
    begin
    score1 = score1+2;
    end
    else if (sw1==0 || sw4==0)
    begin
    score1 = score1+1'b1;
    end
    end
    else if(ledBlink == 2)
    begin
    LED = D2;
    if(sw2==0 && sw3==0)
    begin
    score1 = score1+2;
    end
    else if (sw2==0 || sw3==0)
    begin
    score1=score1+1'b1;
    end
    end
    else if(ledBlink == 3)
    begin
    LED = D3;
    if(sw3 == 0)
    begin
    end
    end
    else if(ledBlink == 4)
    begin
    LED = D4;
    if(sw4 == 0)
    begin
    end
    end
    else if(ledBlink == 5)
    begin
    LED = D8;
    if(sw4 == 0 )
    begin
    end
    end
    else if(ledBlink == 6)
    begin
    LED = D7;
    if(sw3 == 0)
    begin
    end
    end
    else if(ledBlink == 7)
    begin
    LED = D6;
    if(sw2 == 0)
    begin
    end
    end
    else if(ledBlink == 8)
    begin
    LED = D5;
    if(sw1 == 0)
    begin
    end
    end
    else
    begin
    LED= off;
    end
    if(score1 == 10)
    begin
    score1 = 0;
    score2 = score2+1;
    end
    end
    else
    begin
    ButtonT=ButtonT+1'b1;
    end
    end
    --- Quote End ---
    I tested debouncing like on embdded C which I think cannot be implemented here in verilog programming, like this.
    --- Quote Start ---
    begin
    LED = D3;
    if(sw3 == 0)
    begin
    while (sw3 == 0); // I think it can't be implenmented here. :(
    end
    end
    --- Quote End ---
    THANK YOU!
    --- Quote Start ---
    --- Quote End ---
    When I debounce signals, I use a small statemachine and registers. I have the code in VHDL, not Verilog, so I'll just describe it.
    1) Synchronize the button to the local clock using dual-DFF synchronizer.
    Lets call this signal 'button_sync'
    2) Delay the synchronized signal using a single DFF
    Lets call this signal 'button_delay'
    3) Define a signal that is the XOR of these two signals
    assign button_change = button_delay ^ button_sync;
    This signal will be high when there is a change in logic level.
    4) Use a state machine and a counter to control a 'button_debounce' register.
    When the 'button_change' signal asserts, the state machine transitions from IDLE to the CHANGE state. On the transition load a counter with the debounce time (use a down-counter, so that carry-out can be used to detect termination). While in the CHANGE state, enable the counter.
    If the change signal asserts while in the CHANGE state, then reload the counter. Only when the timer terminates do you update the 'button_debounce' output. This logic ensures that the signal is in a valid asserted or deasserted state for at least the debounce time.
    Create a testbench for your debounce component, and edit/debug until you can debounce a signal.
    The above description should get you most of the way there.
    If you have trouble, I'll post the VHDL code and its testbench. You can use that as the reference.
    Cheers,
    Dave
