binupr
2 years agoSignaltap waiting for clock on PCIe example design
Hi there, I am running PCIe example design on AGF027 development kit. I am running Gen4, 1x16 Endpoint reference design. Using Signal tap to check basic functionality. I ran through the process as m...
- 2 years ago
Hi Wincent,
Finally narrowed down the issue.
Issue was that the Switch selection option for PCIe reference clock mentioned in Intel/Altera AGF027 dev kit user guide was incorrect and this led to the clock buffer put in wrong input mode.
Below is screenshot from User Guide.
Switch 4.3 should be set to OFF to receive local clock. As you can see the documentation suggests setting to be ON to receive local clock.
Could you please feed this back to the corresponding documentation team within Intel/Altera to get this updated?
Binu
sstrell
2 years agoCan you temporarily try some other sampling clock just to make sure the issue is with this clock? You'll have to recompile, but it will help you narrow down the problem.
