Engineer1981's avatar
Engineer1981
2 years ago
Set up a NIOS 2 hello world with DE1-SoC rev f with quartus 18.1(elf file failed)
Good evening, I am compiling for a demo a simple hello world example for DE1-SoC rev f using qsys I have assembled nios2 , onchip and usbjtag, the synthesis is successful and also I have assigned the clk_clk to pin ab27 (location) ... The compilation show me just some warning about that( node was determined to be a clock but was found an associated clock ) . Board is also programmed correctly but if I run the hello world and attack the HW via JTAG USB the result is the message of elf failing. I really do not understand why... Any suggestion? Sorry for the detailed explanation but I'm trying to give a scenario of the problem.
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    Back to your issue, what kind of error that you are looking at?
    Could you see if the Nios procesor in the jtag chain when you issue the command "jtagconfig -n"?
    As a reference there is a how-to to create a NiosII hello world in the link below:
    https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset02/nios-ii-hello-world-a10.pdf
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Do you have any follow up question on this case?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Jingyang, Teh
