fa_fpga_enthusiast
2 years agoSeeking DDR4 RDIMM x8 (2666 MT/s) for Agilex-7 (DK-SI-AGI027FA) Evaluation Board
Dear Intel support, The DDR4 DIMM module with RDIMM memory format that is currently shipped with the Intel Agilex-7 (DK-SI-AGI027FA) evaluation board supports 4 DQ pins per DQS group, making it inco...
AdzimZM_Altera
2 years agoHello,
Thank you for submitting your question in Intel Community.
I'm Adzim, will assist you in this case.
Based on your criteria of the RDIMM, the preset setting will limit to RDIMM that has 2 rank x8 organization and 8GB density.
There are some RDIMM that available based on preset setting but I'm not sure if it's available in stock or not.
Some RDIMM 8GB 2 rank x8 2666-speed grade:
- https://memory.net/product/m393a1g43eb1-ctd-samsung-1x-8gb-ddr4-2666-rdimm-pc4-21300v-r-dual-rank-x8-module/#:~:text=Get%20%E2%9E%A1%EF%B8%8F%20Lifetime%20warranty%20%E2%9C%93%20Great%20savings,DDR4%2D2666%20RDIMM%20PC4%2D21300V%2DR%20Dual%20Rank%20x8%20Modules
- https://memory.net/product/hma41gr7bjr8n-vk-sk-hynix-1x-8gb-ddr4-2666-rdimm-pc4-21300v-r-dual-rank-x8-module/#:~:text=Get%20%E2%9E%A1%EF%B8%8F%20Lifetime%20warranty%20%E2%9C%93%20Great%20savings,DDR4%2D2666%20RDIMM%20PC4%2D21300V%2DR%20Dual%20Rank%20x8%20Modules
So I would suggest you to contact with Intel Distributor that available in your location to check on available RDIMM.
You may find Intel Distributor in here: https://www.intel.com/content/www/us/en/partner/showcase/partner-directory/distributor.html#sort=relevancy
Adzim
