Winston_Sun
5 years agoSDC timing constraint cannot be applied during compilation
Hi, I'm currently working on the JESD204C intel FPGA example design on Stratix 10 TX and getting timing violations (fig 1). When I check the warning, it is because the signals are ignored ("could not...
SyafieqS
5 years agoHi Sun,
Try to remove and add again the script and compile it to see if it reflect any changes
- Winston_Sun5 years ago
Hi, I removed and re-add the sdc file to the project (in Project -> Addd/Remove Files in Project...) and compiled, but still shows all the clocks and signals in the sdc file are ignored.
warning examples:
Warning (332174): Ignored filter at intel_j204c_ed_rx_tx.sdc(42): u_j204c_rx_tx_ss|jesd204c_duplex_phy|jesd204c_duplex_phy|j204c_phy_hip_inst|inst_xcvr|tx_clkout|ch0 could not be matched with a clock File: /nobackup/wsun2/jesd204c_remove_addr_concat/ADI_SPI_JESD204C_Nios_Styx_test_design/ADI_SPI_JESD204C_TX_design/hardware/ed/rtl/du/intel_j204c_ed_rx_tx.sdc Line: 42 Warning (332174): Ignored filter at intel_j204c_ed_rx_tx.sdc(42): u_j204c_rx_tx_ss|core_pll|core_pll_clk_1x could not be matched with a clock File: /nobackup/wsun2/jesd204c_remove_addr_concat/ADI_SPI_JESD204C_Nios_Styx_test_design/ADI_SPI_JESD204C_TX_design/hardware/ed/rtl/du/intel_j204c_ed_rx_tx.sdc Line: 42The top qsys sdc file, intel_j204c_ed_rx_tx.sdc, is shown in qsf file as
set_global_assignment -name SDC_FILE ../rtl/du/intel_j204c_ed_rx_tx.sdc
