Rules for pin planner
- 3 years ago
Hi Junyong,
The design example that you have downloaded is targeting Stratix 10 GX Development Kit.
It's cannot be used for Stratix 10 TX Signal Integrity Dev Kit.
The reason is that the design example is not compatible.
The error message that you have shown is related to external memory interface.
The Stratix 10 TX Signal Integrity Dev Kit doesn't has an external memory on the board.
The pin allocated in the design example is targeting Stratix 10 GX device.
When changing the to other device, the pin assignment need to change to targeted device pin location.
There are a lot of differences between the Stratix 10 GX and Stratix 10 TX devkit.
So you cannot simply run the Stratix 10 GX design example in the Stratix 10 TX devkit.
You may tried to use the design examples that have been included in the ZIP file of the development kit.
Adzim
Hi Junyong,
Adzim
- Junyong3 years ago
Hi Adzim,
Thanks for your reply. It was very helpful to me.
The conclusion is that I can't use the Stratix10 Tx Signal Integrity Dev Kit to run the project of PCIe.
Then, I have a question regarding the Stratix10 Tx SI Dev Kit. Doesn't this kit support the PCIe data transmission, becuase it has no PCIe connector?
Best,
Junyong
- FvM3 years ago
the conclusion is that you can't use the Stratix 10 GX design example because it doesn't fit your board. You can generate a PCIe example design with a pin assignment fitting the board, but it won't directly plug into a standard PCIe PC Slot, e.g. use some kind of adapter.
