17 years agoRS232 communication with a MAX 2 CPLD
Hi everyone, I'm trying to send data (8 bits) from my CPLD MAX2 to my computer using the RS232 protocol but I don't find anything good. First, I have tried the SOPC RS2323 module witch give ...
17 years agoHi, It's me (again:rolleyes: )
I have some problem to realise a part of my program. In this part, I want to test 10 wire. To do that, I send by 10 output a sinple bit and I check by 10 other input pin if the bit is transmitted. Each wire is simply connected pin output to pin input (with resistance and other elecronique security). I need to check each wire lonely and in the order 0 to 9 with one at each clock cycle To start this part, I tried to send a bit on each wire lonely and wrote this very simple vhdl code : --- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity VHDL_V1 is port ( CLK : in std_logic; -- Sample CLK --BUSIN : in std_logic_Vector(7 downto 0); -- BUS commun aux sections REF : buffer std_logic_vector(9 downto 0) -- Alimentation des differentes sections ); end entity; architecture numero1 of VHDL_V1 is begin VHDLProc : process(CLK ,REF ) begin for i in 9 to 0 loop wait until clk = '1'; REF(i) <= '1'; wait until clk = '0'; end loop; end process; end numero1; --- Quote End --- The compilation windows say "ok" and the simulation too but in the simulation report, my output REF doesn't change. Do you understand why ? It's my first code written in vhdl so it can be bad but I don't know where...:confused: Do you have an idea ?
