17 years agoRS232 communication with a MAX 2 CPLD
Hi everyone, I'm trying to send data (8 bits) from my CPLD MAX2 to my computer using the RS232 protocol but I don't find anything good. First, I have tried the SOPC RS2323 module witch give ...
17 years agoI correct with
--- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity CustclockV3 is port ( Clk : in Std_Logic; -- Sample CLK clkout : buffer Std_Logic; div : in unsigned (7 downto 0)); end entity; architecture RTL of CustclockV3 is signal clkcount : unsigned(7 downto 0); CONSTANT BAUD : unsigned(7 downto 0) := div; begin -- ClockProcess ClockProcess : process(Clk) begin if Rising_Edge(Clk) then if clkcount < baud-1 then clkcount <= clkcount + 1; clkout <= '0'; else clkout <= '1'; clkcount <= (others => '0'); end if; end if; -- RisindEdge(clk) end process; end RTL; --- Quote End --- but it doesn't work because the program dosn't recognise the sign < (in clockprocess)I suppose that it keep the binary numbers and not the value of it. Should I make a translation line to convert unsigned (00000010) into number (2) ? If yes, how can I do that because I must do that in an other part of my program and I havn't already find the solution?
