17 years agoRS232 communication with a MAX 2 CPLD
Hi everyone, I'm trying to send data (8 bits) from my CPLD MAX2 to my computer using the RS232 protocol but I don't find anything good. First, I have tried the SOPC RS2323 module witch give ...
17 years agoI have wrote this clock generator using your RS232 code (thx :-) and it works.
But to use it simply, I want to put the value 133 (INTEGER) as a variable. In fact I use this code in a block with my 66.6Mhz clock in input and my created clock in a output, and I want to add an other input with a 16 bit constant value to change easily the clock divider. All solutions that I try doesnt work and altera show me an error screen so is it really possible to do that? I don't know if you have understand my question but, in advance, thanks --- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity CustclockV3 is port ( Clk : in Std_Logic; -- Sample CLK clkout : buffer Std_Logic); end entity; architecture RTL of CustclockV3 is signal clkcount : unsigned(7 downto 0); CONSTANT BAUD : INTEGER := 133; -- 500kHz @ 66.66 MHz begin -- Tx Process TxProc : process(Clk) begin if Rising_Edge(Clk) then if clkcount < BAUD-1 then clkcount <= clkcount + 1; clkout <= '0'; else clkout <= '1'; clkcount <= (others => '0'); end if; end if; -- RisindEdge(clk) end process; end RTL; --- Quote End ---
