18 years agorookie question: program the flash on Stratix II GX PCIe board
I just started using the Stratix II GX PCIe dev board. I was able to load some simple designs to the FPGA and they seem work alright. Now I want to write the design to the flash so the FPGA load the ...
18 years agosimollie,
I recently went through the same step. Refer to page 13 "Programming with the POF" in the PCI Express High Performance Reference Design for instructions on how to write a design to flash: http://www.altera.com/literature/an/an456.pdf If you need the design files, they can be downloaded at: http://www.altera.com/literature/an/an456_pcie_hpdemo71.zip Hope this helps. -lapata101
