15 years agorestore_my_flash problem with my Nios II Development Kit Cyclone II Edition
I'm trying to restore my board following this instructions: 1) Open command shell 2) cd factory_recovery/niosII_cycloneII2c35 3) ./restore_my_flash "restore_my_flash" command produce this error:Can't locate strict.pm in @INC (@INC contains: /usr/lib/perl5/5.8/cywin /usr/lib/perl5/5.8 /usr/lib/perl5/site_perl/5.8/cywin /usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/vendor_perl/5.8/cywin /usr/lib/perl5/vendor_perl/5.8 /usr/lib/perl5/vendor_perl/5.8 .) at resore_my_flash.pl line 18.
BEGIN failed--compilation aborted at restore_my_flash.pl line 18.I work with Windows 7 pro 64 bit, Quartus II 10.0sp1 web edition and Nios II EDS 10.0sp1. After this error I installed "Strawberry Perl for windows" but the situation doesn't change. Thanks! Andrea5 Replies
Try with this command in the command shell from the folder containing the restore FLASH file provided,
nios2-flash-programmer --base=(whatever applies) --cable='USB-Blaster [USB-0]' ******.flash Good luck. - Altera_Forum
I'm trying with
I omit "--cable" becouse I've only one USB Blaster, but I don't know what "FLASH Base address" is. Anyway I suppose that it is a workaround, how can I solve my problem? Thanks a lot!nios2-flash-programmer restore_cycloneII_2c35.flash - Altera_Forum
I found in the documentation of my eval kit that I needed to use a particular base address in the flash for loading my .flash file. That's what I used.
I suppose that the 'restore_my_flash' shell script was written by you. While entering it in the command shell, try entering it as './restore_my_flash.sh'. Might help. good luck. - Altera_Forum
"restore_my_flash" is not my script.
I follow the "Appendix A. Restoring the factory Configurations" from the "Nios Development Board - Cyclone II edition" reference manual. --- Quote Start --- To reprogram the flash memory on the development board, perform the following steps: 1. Open a Nios II command shell. On a Windows PC, click Windows Start, point to Programs, Altera, Nios II EDS <installed version>, and then click Nios II Command Shell. 2. From the examples directory, change to the factory_recovery directory for your development kit. cd factory_recovery/niosII_cycloneII_2c35 3. Run the flash-restoration script: ./restore_my_flash 4. Follow the script's instructions. --- Quote End --- The procedure is simple, I only have to launch the script, nothing else. I don't understand what is wrong. - Altera_Forum
I decided to install the software version 8.0 instead of 10.0 and it works.
Thanks for help. bye
