Request of AXI bridge example for CycloneVsoc HPS to FPGA communication
- 2 years ago
Hi Alex
The dword read is the maximum size that is available by the library to read through the bridge.
Is reading using the dword improve the situation on your end?
The difference between a normal and burst command is the in the burst command there are addtional signals such as ARBURST, ARSIZE ,RLAST.
In the burst command it will have state the number of burst read from the receiver to send the data.
https://docs.xilinx.com/r/en-US/ug1399-vitis-hls/AXI-Burst-Transfers
Jingyang, Teh
Hi Alex
Any update on this case?
Do you have any question on the example design?
Jingyang, Teh
- CAlex2 years ago
Contributor
Yes , a lot of questions, mainly about what do these IP do and how to do it properly.
I need more time for this example,
but the understanding itself is not related to this thread.
I'll open a new thread if there are quesions I can't figure out.
Please do what you need to do to this thread.
Thank you for your help.
Reguards.
