CAlex
Contributor
2 years agoRequest of AXI bridge example for CycloneVsoc HPS to FPGA communication
Hi I've tried the AVALON MM bridge HPS to FPGA translating 32 bit data for each using alt_write_word() and alt_read_word(). There is ~2us latency between orders(128bit wide H2F bridge with 50MHZ cl...
- 2 years ago
Hi Alex
The dword read is the maximum size that is available by the library to read through the bridge.
Is reading using the dword improve the situation on your end?
The difference between a normal and burst command is the in the burst command there are addtional signals such as ARBURST, ARSIZE ,RLAST.
In the burst command it will have state the number of burst read from the receiver to send the data.
https://docs.xilinx.com/r/en-US/ug1399-vitis-hls/AXI-Burst-Transfers
Jingyang, Teh
tehjingy_Altera
2 years agoHi Alex
Please do take a look at the example.
There would be some delay in between each read.
By using the DMA it will speed up the process and also free up your resource for other stuff.
Jingyang, Teh
