Request for Confirmation "112465"
Hello Ehab,
Please find the attachment "Intel DCL Product Content REACH Jan 2023".
I hope this will address your request.
If there is any questions, please do let me know.
Wani
Correction. Please refer to Intel DCL Product Content REACH Jun 2023.
Thanks!
Wani
- Ehab2 years ago
Hello Team,
I hope this email finds you well.
Thanks for the shared data, but the attached CoC doesn't contain the substance "2,4,6-Triamino-1,3,5-Triazine" with CAS "108-78-1" but based on the part's FMD "https://cdrdv2.intel.com/v1/dl/getContent/699065?fileName=EP4CE15F17C8N_20210716113054_v1.xml" the part contains it, and this substance is an SVHC substance, so the part should not be compliant with REACH SVHC. Could you please check and clarify the REACH status of the PN?
Thanks in advance for your support.- Ehab2 years ago
Hello Team,
I am just following up with you regarding the request below to see if you have any updates.
Your cooperation will be greatly appreciated. - Ehab2 years ago
Hello Team,
We would like to follow up on the request sent below, as we have not received a reply yet.
The attached CoC doesn't contain the substance "2,4,6-Triamino-1,3,5-Triazine" with CAS "108-78-1" but based on the part's FMD "https://cdrdv2.intel.com/v1/dl/getContent/699065?fileName=EP4CE15F17C8N_20210716113054_v1.xml" the part contains it, and this substance is an SVHC substance, so the part should not be compliant with REACH SVHC. Could you please check and clarify the REACH status of the PN?
