Reprogram Stratix 10 - Base Addresses are not being updated
- 3 years ago
Hi james57,
Referring to build SD card section from the building bootloader document below, the yocto build is only for the rootfs.
You can considered the pre-build image for rootfs. Any file changes related to you FPGA design will be required to change accordinly unless it is unaffected to the whole project build when packaging the whole file into sdcard.img.
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7#Build_SD_Card_Image
Aik Eu
Hi james57,
Aik Eu
