Regarding the issue with the I2C Remote System Upgrade Example
Did you first confirmed the UART testing with Helloworld example on the both boards?
If above is tested then also confirm on below
Are you using the proper relevant images on the boards for this I2C remote update. These examples are for the below boards-
Max 10M50 Development Kit
Max 10M08 Evaluation Kit
Also, did you prepared the setup between these two board as
Tiwari
Do you have a UART testing with Helloworld example for the Max 10M50 Development Kit board?
- Miles13 years ago
I have successfully confirmed the UART testing with Helloworld example on the Max 10M50 Development Kit
What should I do next?
- Miles13 years ago
I am following the I2C Remote System Upgrade Example provided by the official documentation.
However, when executing the steps on page 17 to send Slave Image 1 and Slave Image 2 via UART, I found that UART is not able to send out messages properly.
I am unable to see the LOG messages as shown in the file provided.
