Miles1
3 years agoRegarding the issue with the I2C Remote System Upgrade Example
I am using the 10M50D development board, ALTERA MAX 10 FPGA DEVELOPMENT KIT, to validate the I2C Remote System Update project as shown in the figure below. I am following the I2C Remote System Upgrad...
Jeet14
3 years agoHi,
Are you able to run helloworld example w.r.t. UART on both boards just to conform that UART's are working?
To run this I2C remote system upgrade example you need to use below setup-
Quartus II v15.1 with the NIOS II Software Build Tools for Eclipse.
Max 10M50 Development Kit
Max 10M08 Evaluation Kit
Wires
Two 5kohm resistors
Some method of building a simple circuit (e.g. breadboard or soldering iron)
Once you tested in this Quartus II v15.1 then later you can upgrade this design to newer versions.
Tiwari
