18 years agoRegarding ADC in DSP 2S180 board
hi all, i have been working on altera dsp board (2s180), where i am sampling simple sine wave ( using sine wave generator) using on board adc (ad9433). i am using a pll setting my sampling freq...
18 years ago --- Quote Start --- The ADC circuit is shown at page 39 and 40 of Stratix II DSP Board schematics. Clock AC coupling is not an issue, cause cutoff frequency is much lower than specified minimum sampling frequency, but analog in AC coupling is. Transformer coupling is an effective way to produce a differential signal with good common mode rejection, if DC and low frequency components aren't of interest. To transmit DC signals, a differential amplifier would be used instead. --- Quote End --- Ok let me look it up, I will come back and bug you after i read it thank thank you so much Happy easter :) Regards DSPboard
