EP2SGX60EF1152C5N
4 years agorecommend Stratix II GX EP2SGX60EF1152C5N replaced parts
Stratix II GX EP2SGX60EF1152C5N end of life. Can you please recommend a alternative part?
Below points are preferred.
1. FPGA code change is small.
2. Pin-to-Pin replace is preferred. No need change...
Ash_R_Altera
4 years agoHi,
As per the PDN, there is no recommended replacement part. For your design migration, you will have to check newer families on Intel FPGA. Design changes depend on how many FPGA hard blocks or primitives are directly instantiated. Also if any IPs used, they will also need to be newly generated.
