lambert_yu's avatar
lambert_yu
3 years ago
receiver error for multi-simplex receivers application (transceiver arria 10)
Hi all,
FPGA : 10AX115N2F45E1SG
simplex rx count : 16
pin assignment : four channel from 4c, four channel from 4d, four channel from 4e,four channel from 4f.
ref clock : single 62.5Mhz from 4e bank
power of transceiver : 1.03V (1_0V in IP, short reach).
connection : chip 2 chip (two 10ax115N2F45E1SG fpga board, one is TX, one is RX)
link loss < 10DB
Speed : 1Gbps/2Gbps/5Gbps.
issue : for some boards, it could receive pattern correctly (1/2/5Gbps); some board, there's error for some lane(1/2/5Gbps) when we run prbs18 test. For the board with error, we run the loopback test, there' no error.
analysis: We check the eye diagram after ac-couple about the error lane, it's eye height and eye width is okay; and they all can pass loopback test. So I think there's problem at RX analog frontend, and we check the refclk and power supply, it's okay. I do not know which factor will I need to consider except that.
Could someone help me?
BRs,
Lambert
  • ZiYing_Intel's avatar
    ZiYing_Intel
    Hi Lambert,
    Glad to hear that your case passed already. I am now close the case. If you have any issue after the case closed, please do feel free to submit another issue. There will have people reach out to you.
    zying
