15 years agoRead host PC data using HAL
I've spent the past 8 hours trying to read data from my host Windows PC using a C program running on NIOSII. And finally I found light with that Host File System business! I thought it would be good ...
15 years agoIt may not possible to send file to CPU if it is not in the debug mode.
Just because this method is using gdb. This function only available when you use the debug mode.
