16 years agoread data from SSRAM (IS61LPS25636A)) on Cyclone III starter board
Anybody know how to read data from SSRAM (IS61LPS25636A)) on Cyclone III starter board? I followed the datasheet, but still could not read the data correctly. My code is as follows
`timescale 1ns / 1ps module mem_read( ssram_clk, clk, reset_n, ssram_adsc_n, ssram_bw_n, ssram_bwe_n, ssram_ce_n, flash_ssram_a, flash_ssram_d, ssram_oe_n, test_led ); input ssram_clk; input clk; input reset_n; output wire ssram_adsc_n; output wire [3:0] ssram_bw_n; output wire ssram_bwe_n; output wire ssram_ce_n; output wire [19:2] flash_ssram_a; input [31: 0] flash_ssram_d; output reg ssram_oe_n; output wire [3:0] test_led; assign ssram_adsc_n=1'b1; assign ssram_bw_n=4'b1111; assign ssram_bwe_n=1'b1; assign ssram_ce_n=1'b0; // assign flash_ssram_a=counter1; // assign ssram_oe_n=1'b0; reg [1:0] counter; always@(posedge ssram_clk, posedge reset_n) begin if (reset_n) counter <=2'b00; else if (counter1==18'b111111111111111111) counter <=2'b00; else if (counter==2'b11) counter <=2'b01; else counter <= counter + 2'b1; end //counter reg [17:0] counter1; always@(posedge clk, posedge reset_n) begin if (reset_n) begin counter1 <= 18'b111111111111111111; end else if (counter1==18'b111111111111111111) counter1<=18'b000000000000000000; else begin counter1<=counter1+18'b1; end end assign test_led[0]=reset_n; assign flash_ssram_a =counter1; always @(negedge ssram_clk, posedge reset_n) begin if (reset_n) begin ssram_oe_n <=1'b1; end else if (counter1==18'b111111111111111111) begin ssram_oe_n <=1'b1; end else if (counter==2'b01||counter==2'b11) begin ssram_oe_n <= 1'b1; end else if (counter==2'b10) begin ssram_oe_n <= 1'b0; end else ; end endmodule3 Replies
Please do not multipost, and "still could not read the data correctly" is quite vague...
I have a query and that is, whether it is possible to write the ssram from outside nios like in vhdl code but read from nios to process the data?
It is possible. You should create your own custom SOPC component with an avalon master interface. The SOPC system will then share the RAM access between your component and the Nios CPU.
