aamodini
2 years agoRead data from Avalon-MM FIFO
I am writing data into an Avalon-MM FIFO using Nios. Is it possible to read data from this FIFO inside the FPGA fabric using Verilog?
sstrell
2 years ago"Is it possible to" what? "data from this FIFO..."
Critical word seems to be missing from your question. If you mean "read data" then yes, you would do a read from the output side of the FIFO.
Maybe more clarification is required.
aamodini
2 years agoMy bad, I have edited the post. Yes, I meant to ask if we can read data. I would like to know the steps for the same.
I am using the Avalon FIFO IP component to write data into from the Nios side.
In order to read this data from the fabric, do I have to write a slave interface module (like a wrapper) and connect the signals to the FIFO instance?
Also, would a simple read-from-FIFO logic look something like this?
