Stratix 10 SoC Dev Kit - L-tile - FPGA-DDR4 (SODIMM ) Example design
Thanks for reproducing the problem & it will be great if Intel supports how to solve this.
Regarding the example design, I have done something similar as mentioned in the "External Memory Interfaces Intel® Stratix® 10 FPGA IP Design Example User Guide". However, I will once again correlate between this document & my design & keep you posted.
Wit Regards,
HPB
I'm glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- bradgiordano5 years ago
I wanted to check with you to see if the Intel Stratix-10 SOC Dev Kit can be upgraded from 16GB to 32GB of DDR4 FPGA memory.
- HBhat25 years ago
Contributor
I followed the same procedure & tried to test the interface. Calibration is failing. I have attached the QAR file. Can anybody check the EMIF memory controller settings & point out what went wroung?
Quartus tool used: 18.1
Stratix 10:
FPGA DDR4 part number : MTA18ASF2G72HZ-2G3B1ZG
https://www.digikey.in/htmldatasheets/production/1959037/0/0/1/MTA18ASF2G72HZ.pdf
2400MT/s, CK/CK# freq :1200MHz,
CL = 17, tRCD = 17, tRP = 17
PLL ref clk: 100MHz or 166.66MHz (as per Platform designer recommendation)With Regards,
HPB
