Stratix 10 SoC Dev Kit - L-tile - FPGA-DDR4 (SODIMM ) Example design
Yes, I have downloaded the package & tried to create the project as mentioned in the readme file.
I ran the below command in command prompt & I am getting the error message while creating the project
quartus_sh -t make_qii_design.tcl
Error (23035): Tcl error: child process exited abnormally
while executing
"exec -ignorestderr $qsys_generate_exe_path $qsys_file --pro --synthesis --family=$family --part=$device >>& ip_generate.out"
(file "make_qii_design.tcl" line 98)
while executing
Error (23031): Evaluation of Tcl script make_qii_design.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 4871 megabytes
Error: Processing ended: Tue Aug 25 09:59:37 2020
Error: Elapsed time: 00:00:23
I am using Quartus pro 18.1 & licensed for stratix 10 device.
With regards,
HPB
I can reproduce this error. You can refer to below link to generate a example design based on the emif component in ed_synth.qsys locate in emif_s10_0_example_design folder.
https://www.intel.cn/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20120.pdf
- HBhat26 years ago
Contributor
Thanks for reproducing the problem & it will be great if Intel supports how to solve this.
Regarding the example design, I have done something similar as mentioned in the "External Memory Interfaces Intel® Stratix® 10 FPGA IP Design Example User Guide". However, I will once again correlate between this document & my design & keep you posted.
Wit Regards,
HPB
- ybin6 years ago
I'm glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- bradgiordano5 years ago
I wanted to check with you to see if the Intel Stratix-10 SOC Dev Kit can be upgraded from 16GB to 32GB of DDR4 FPGA memory.
