Himanshu_Varia
24 days agoGuidance on Enabling USB Mode in F-Tile PMA Direct PHY IP – Quartus Prime 26.1
Hello, I am currently working on USB 3.x data-rate implementation using the F-Tile PMA Direct PHY IP in Quartus Prime for the Agilex 7 device. In earlier versions of the F-Tile PMA Direct PHY IP, t...
JonWay_altera
22 days agoIn Quartus Prime Pro 26.1, USB is no longer a supported selectable value for FGT PMA Configuration Rules in the F-Tile PMA Direct PHY IP. The current supported values are Basic, OTN, CPRI, GPON, SDI, SONET, HDMI, SATA/SAS, PCIe, and PCIe_Phase2; USB is not listed.
There is no documented Tcl command or QSF assignment that restores the former USB configuration. The USB-specific ports and simplified TX interface were generated by the old USB protocol rule; they cannot be reliably recreated by manually setting ordinary PMA parameters.
