Suresh430
2 months agoARM DS5 debugger Access/Detection of CM55 on Agilex5 fpga device
Hi Team, We recently purchased license for the ARM DS5 IDE from Altera with License file contains note as NOTICE="For use with Intel or Altera devices only". I am using Arm Develop...
Suresh430
1 month agoHi Tehjingy,
Thanks for the update.
case 1:
case 2 :
above case 1 or case 2 are possible to implement ?
Suresh
tehjingy_Altera
1 month agoHi Suresh430
Case 2 would be the route you should look at.
The Virtual JTAG IP does not have the protocol to connect to the CoreSight DAP.
If you would like to connect it through the Virtual JTAG IP you would need to create the "JTAG to Coresight bridge IP" which would connect the Virtual JTAG IP to the Coresight DAP, which is currently unavailable in the Catalog IP.
