s1
10 days agoAgilex 5 E-Series 013B Development Kit User Guide SW4.2 (spread spectrum) description is inverted
The description of DIP switch SW4.2 in the Agilex 5 FPGA E-Series 013B Development Kit User Guide (ID 860700, version 2026.10.02) is inverted and contradicts the board schematic. User guide (Table 4...
- 9 days ago
I had filed ticket to update the document information. Thanks for your pointings.
ShengN_altera
9 days agoGood catch — the SW4.2 description in the 013B Development Kit User Guide is inverted relative to the schematic and hardware. The schematic and your hardware test are correct:
- SW4.2 OFF (factory default) — spread spectrum disabled
- SW4.2 ON — spread spectrum enabled
Regarding the TX PLL lock failure you observed with SW4.2 ON: this is the expected consequence. The GTS PMA/FEC Direct PHY IP has a Spread Spectrum parameter that specifies whether the TX PLL reference clock is spread spectrum, with a default value of DISABLE. Table 39. GTS PMA Transmitter Analog Settings — GTS Transceiver PHY User Guide Agilex 5 When the Enable TX PLL real-time lock status parameter is selected, the
o_tx_pll_locked signal indicates the real-time lock status of the TX PLL, and the lock signal deasserts when the reference clock is not available or the reference clock frequency is incorrect. 3. Implementing the GTS PMA/FEC Direct PHY IP — GTS Transceiver PHY User Guide Agilex 5 With SW4.2 ON (SS enabled on the Si5332 output feeding PCIE_EP_REFCLK), the reference clock is frequency-modulated. If your GTS PMA/FEC Direct PHY IP instance has Spread Spectrum left at its default (DISABLE), the TX PLL sees a continuously varying input frequency and correctly refuses to assert real-time lock. Setting SW4.2 OFF (SS disabled) restores a stable reference clock frequency and lock is achieved — consistent with what you observed.
If you need spread spectrum on the PCIe reference clock path, note that spread spectrum clocking mode cannot be used when you select the Enabled TX PLL fractional mode option, and spread spectrum is not supported when you use the fast PLL mode type. Table 39. GTS PMA Transmitter Analog Settings — GTS Transceiver PHY User Guide Agilex 5 You would need to set Spread Spectrum = ENABLE in the IP parameter editor and verify neither of those exclusions apply to your configuration.
Please report the SW4.2 description inversion in ID 860700 through the documentation feedback channel so it gets corrected in the next revision.
