CTLIM
2 years ago5CSEBA2U23C7SN
Hello, Can someone please share me failure analysis request link? We are having problem with below part where the signal "DIFFIO_TX_B41N/RZQ_0" point with the "GND” point ohm value not able to get...
Zawani_M_Intel
2 years agoThank you for contacting Intel FPGA Community Forum.
Please be noted that we requires details information to understand further your issue. Please help to answer questions below in order for us to better understand your position.
1. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
2. What is the failure symptom? Please elaborate the failure symptom in detail.
3. When did the failure happen? How did you discover the failure?
4. How did you determine the failure? Please elaborate the procedures.
5. Does the failure unit ever working before failure?
Thank you!
Wani
