15 years agoRapidIO IP in Cyclone III EP3C120F780 FPGA ???
Can any one you tell me does the RapidIO from Altera is supported by the Cyclone III FPGA Development Kit containing Cyclone III EP3C120F780 FPGA This question arise because in the RapidIO Me...
15 years agoI think that you could connect the external PHY interfaces between two RapidIO IPs inside one FPGA, and it should work... But I never tried it.
What do you want to test exactly? Using such a setup it won't be a serial interface anyway, but an 8-bit parallel. You won't test the interface with an external serdes either.
