ccoda
7 years agoRapidIO, FibreChannel, DDR3 and LVDS at
Hello! I want to use Cyclone V - 5CGTFD9E5F35I7 in one of my projects. I've got to route the following interfaces: FibreChannel - 5 lines [ 2112 Mbit/s ] FibreChannel - 1 line [ 250 Mbit/s ] Ser...
Nathan_R_Intel
Contributor
7 years agoHie,
Cyclone V GT only supports high speed differential LVDS IO channels up-till speed of 840Mbps. For the rest, you will need to use transceiver channels.
The Cyclone V GT device you are using has 12 transceiver channels.
Cyclone V GT transceivers support data rate from 614Mbps till 5Gbps.
Hence, only the following can be supported by Transceiver Channels:
FibreChannel x 5 at 2.112Gbps
Serial Rapid IO x 2 at 5Gbps
Fibre Channel x 1 at 250Mbps cannot be supported by transceiver channels directly. Hence, recommend to use differential LVDS High Speed IO.
However, if you still want use the Transceiver channels, please use oversampling but configure the transceiver channels at 1Gbps.
Hence, you can use the following channel placement to support your interface requirement:
To get the Quartus to Pass Fitter, please specify the pin placement as following.
For Cyclone V GT, you will need to use one transceiver channel as Tx PLL; hence that channel cannot be used.
Bank 1
CH5 - Fibre Channel at 2.112Gbps
CH4 - Fibre Channel at 2.112Gbps
CH3 - Fibre Channel at 2.112Gbps
CH2 - Fibre Channel at 2.112Gbps
CH1 - use as CMU PLL (2.112Gbps)
CH0 - Fibre Channel at 2.112Gbps
Bank 0
CH5 - Serial Rapid IO x 2 at 5Gbps
CH4 - use as CMU PLL (5Gbps)
CH3 - Serial Rapid IO x 2 at 5Gbps
CH2
CH1- use as CMU PLL (1Gbps)
CH0- Fibre Channel x 1 at 1Gbps
For clocking, please select as following:
Fibre Channel x 1 at 1Gbps - select non-bonded x1 clock line
Fibre Channel x 5 at 2.112Gbps - select bonded x6 clock line
Serial Rapid IO x 2 at 5Gbps - select bonded x6 clock line
Please refer to following documents on using Transceiver Channels.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
Nathan
