zw_lee's avatar
zw_lee
1 month ago
R-tile CXL base hard IP example for the Agilex 7 M-series Dev Kit (DK_DEV_AGM039EA) does not work
We recently generated an R-tile CXL base hard IP example for the Agilex 7 M-series Dev Kit (DK DEV AGM039EA) with both Quartus Prime Pro 25.3.1 and 26.1. However, the CXL link is always down and stuck at Gen1 2.5Gbps. Do you have any suggestions, or is there a working CXL design example for this kit? We verified that the link functions perfectly with a PCIe Gen5/Gen4 example.We recently generated an R-tile CXL base hard IP example for the Agilex 7 M-series Dev Kit (DK DEV AGM039EA) with both Quartus Prime Pro 25.3.1 and 26.1. However, the CXL link is always down and stuck at Gen1 2.5Gbps. Do you have any suggestions, or is there a working CXL design example for this kit? We verified that the link functions perfectly with a PCIe Gen5/Gen4 example.
    • RongY_altera's avatar
      RongY_altera
      I've never tried CXL on this dev kit. Did you program the flash to boot PCIe?
      Rong
