15 years agoquestions about DMA transmition
hi: I want to transmit data from FIFO to sdram by DMA in SOPC builder. in NIOSII eclipse, if((tx=alt_avalon_dma_send(txchan,(void*)tx_data,0x1000,NULL,NULL))<0) { print...
15 years agohi,gurus
I have try lots of times ,but always failed,so I hope someone can give me help~ the self-made SOPC component is connected to read master port of DMA, SDRAM is connected to write master port of DMA. the setl-made component is connected to avalon bus as a slave interface.when I use "IORD"to read the component,it is right,but when I connect is to DMA,DMA transmits failed~ if((rx= alt_avalon_dma_prepare(rxchan,rx_buffer,1024,done_t,NULL))<0) { printf("rxchan receive failed.reason: %d",rx); exit(1); } dma_prepare always failed, if the self-made component has some problems (the component consist of a FIFO which connected to avalon through slave port )?? The NiosII software code is attached the pogrammme is very urge,and there is nobody around me can give me advise,so I hope you gurus can give me some hints~ thanks very much~~
