ricj
2 years agoQuartus Programmer Crashes when Loading .jic File
This question is related to booting a Cyclone IV FPGA from flash memory. Previously, I used the S25FL064P device and would generate a .jic file using the ECPS64 preset and was able to successfully p...
- 2 years ago
Problem solved.
The .jic file was generated in Linux (Quartus Prime v20.1.1 Build 720 11/11/2020 SJ Standard Edition).
I was trying to use that .jic file in Windows (Quartus Prime v20.1.1 Build 720 11/11/2020 SJ Standard Edition).I tried generating the .jic in Windows (instead of Linux) and saw that the programmer tool no longer crashes when I add the file.
NurAiman_M_Intel
2 years agoHi,
You need to create .jic file using S25FL064L .But you need to define new flash device (S25FL064L ). Follow steps in the userguide below(page12) to define new flash and then create the .jic file.
Aiman
