Chandrashekhar_K
2 years agoquartus_hps -c 1 -o I Command error
We are trying to programm QSPI on custom board. Running the command before programming QSPI. quartus_hps -c 1 -o I quartus_hps -c 1 -o S We are getting the following errors as in the attached scr...
tehjingy_Altera
2 years agoHi
I notice that you are using the quartus_hps tool to program the QSPI flash.
However you are not entering any address for the command.
Please refer the link below on the usage of the quartus_hps tool.
Jingyang, Teh
Chandrashekhar_K
2 years agoDear Jingyang
Even for this command quartus_hps -c 1 -o S I'm getting the same errors as in the attachments. For chip erase the same error.
Would you please help to understand why the WARM REST is generating a continuous pulse as in previous attachment. The pin is pulled to 3.3V with 4.7K ohm.
