Ms_G
3 years agoQuad SPI flash IO Voltage
Hi, I am using winbond quad spi flash - all 4 flash IOs are connected to Cyclone 10 FPGA. 2 IOs are connected to Bank 1, which is at 2.5VDC level 2 IOs are connected to Bank 8, which is at 3.3VD...
EthanLi
3 years agoIf you use Vccio 2.5V for bank 1 and add a voltage translator between flash and FPGA IO, it would be OK for the hard ware.
But since we do not suggest to configure by this way, I am not sure if there could be any other configuration issue, timing or compile errors.
I suggest to use the 2.5V IOs in the other banks and leave the bank 1 as 3.3V powered.
Ethan
