AMa's avatar
AMa
6 years ago
qdb文件导入出错
京东方在使用第三方的一个IP时,将qdb文件导入后综合,出现以下错误,这不太明白咋回事,看着像QDB文件提供方直接导了个完整工程出来了。
Error(18633): The Quartus Database File "SiW_CEDS_TOP_synthesized.qdb" contains a full design and cannot be imported with the import_block command, or as a QDB File Partition assignment.
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Are you using the inport_block command to import the qdb file? To import the Quartus Database File contains a full design, use the import_design command.
    KhaiY
  • AMa's avatar
    AMa
    您的意思是,出现这个错误的原因,是因为qdb文件内包含了整个Quartus工程?​
      KhaiChein_Y_Intel
      Yes, this is what the error message indicates. Have you tried the inport_design command?
      KhaiY
  • AMa's avatar
    AMa
    Hi
    多谢。已解决。暂时没有需求了。​
