Proper PERST# connection for FMC on Agilex5 Modular Development Kit
- 1 month ago
Whether the production Modular Development Kit already has PERST# physically routed from the PCIe edge connector to one of those HVIO pins, or whether you need a board-level modification, is a question specific to that board's schematic. I'd recommend checking the production board schematic (available from the kit webpage) to confirm whether that trace is already present before reaching for a soldering iron. If the board is used in PCIe slot mode, the nPERST line from the slot should reach the board; if it's used in tabletop/standalone mode, you may need to drive that pin from another source (e.g., an on-board logic signal or manual connection).
I was able to get the PCIe link running through FMC. Here are the details so it can help others:
- PCIe link is set up as an endpoint
- Raw PERST from the link is connected to pin BF40 on the 3.3V HVIO bank through the pin 8 on the J23 header (carrier board).
- Internal to the FPGA: PERST is registered for timing and then brought out to pin CF121 on the 1.8V HVIO bank (carrier board net name MIPI_XTRIG0_1V8). This accomplishes the level shifting from 3.3V to 1.8V
- The actual PERST to the HIP is driven by the net MIPI_XHS0_1V8
- The connection between the two nets is accomplished by bridging pins 2 and 4 on the DIP switch S6 on the carrier card. I was able to use debug clips to establish a temporary connection before soldering the wire
Also, for the HIP clock connections I got the link working with either:
- using two clocks:
- AV120: connected to the refclk0 input on the HIP
- AY120: connected to the GTS PLL
- using a single clock:
- AV120: connected to both the HIP and the GTS PLL
- AqidAyman_Altera1 month ago
Thank you for your sharing this information and it is good to know that you are able to get the PCIe link running through FMC.
