Proper PERST# connection for FMC on Agilex5 Modular Development Kit
- 1 month ago
Whether the production Modular Development Kit already has PERST# physically routed from the PCIe edge connector to one of those HVIO pins, or whether you need a board-level modification, is a question specific to that board's schematic. I'd recommend checking the production board schematic (available from the kit webpage) to confirm whether that trace is already present before reaching for a soldering iron. If the board is used in PCIe slot mode, the nPERST line from the slot should reach the board; if it's used in tabletop/standalone mode, you may need to drive that pin from another source (e.g., an on-board logic signal or manual connection).
Thank you for the response.
This question is about the PERST# connection from the FMC board since the RES0/RES1 pins are not used. I do not anticipate issues with the PCIe edge connector.
I have reviewed the schematic connections and documented them in my original post. My hope was that I can get an independent confirmation of my findings before I start soldering and otherwise modifying the board.
I think I will carefully proceed with my project and only modify the board as the last resort.
