Proper PERST# connection for FMC on Agilex5 Modular Development Kit
- 1 month ago
Whether the production Modular Development Kit already has PERST# physically routed from the PCIe edge connector to one of those HVIO pins, or whether you need a board-level modification, is a question specific to that board's schematic. I'd recommend checking the production board schematic (available from the kit webpage) to confirm whether that trace is already present before reaching for a soldering iron. If the board is used in PCIe slot mode, the nPERST line from the slot should reach the board; if it's used in tabletop/standalone mode, you may need to drive that pin from another source (e.g., an on-board logic signal or manual connection).
Thank you very much for the response and the confirmation about 1B bank.
I am trying to create this design on a production version of the modular board. According to the most recent version of "GTS AXI Streaming IP for PCI Express* User Guide" (9/14/2026), the production board requires only one PERST connection and the other can be used as a GPIO: "You can connect PERST# to either one of the reset pins. Assign pin_perst input port of the GTS AXI Streaming IP to the location of the reset pin connected to PERST#. For the reset pin not used for PERST#, it can be used as a generic HVIO signal."
Can you please confirm that I have to do a manual PERST# connection to the board (likely through soldering) to one of the pins listed in the original post? I would like to avoid that if there is a better way to implement the connection.
Thanks again.
