Proper PERST# connection for FMC on Agilex5 Modular Development Kit
- 1 month ago
Whether the production Modular Development Kit already has PERST# physically routed from the PCIe edge connector to one of those HVIO pins, or whether you need a board-level modification, is a question specific to that board's schematic. I'd recommend checking the production board schematic (available from the kit webpage) to confirm whether that trace is already present before reaching for a soldering iron. If the board is used in PCIe slot mode, the nPERST line from the slot should reach the board; if it's used in tabletop/standalone mode, you may need to drive that pin from another source (e.g., an on-board logic signal or manual connection).
The Agilex 5 FPGA E-Series 065B Modular Development Kit feature summary explicitly maps transceiver bank 1B to FMC XCVR Lane 0 to Lane 3 (17 Gbps max), and bank 1A to FMC XCVR Lane 4 to Lane 7. Refer this: Feature Summary
So, your identification of bank 1B as the target for a second x4 PCIe endpoint via the FMC should be correct. The x8 FGT lanes from banks 1A and 1B are terminated to FMC J7. Agilex™ 5 FPGA E-Series 065B Modular Development Kit User Guide
This is the most important thing if you are using an ES device: Due to a problem in the ES devices, assigning either of the two reset pins as PERST# fails to reset the PCIe link. For the Agilex 5 FPGA E-series in the current Quartus Prime software release, you must assign both p0_pin_perst_n_i and p0_pin_perst_n_1_i ports to the location of the reset pins. Why does toggling p0_pin_perst_n_i fail to reset PCI Express* links in the Agilex™ 5 FPGA E-Series ES devices in the Quartus® Prime Pro Edition Software version 24.2?
This means that at the IP level in Quartus, you must assign both ports but at board level, you only physically connect PERST# to one of the two pins. For ES device, if one PERST pin is selected as reset signal for GTS, the unused PERST pin for the same GTS bank must be left floating. When used as PCIe platform reset, connect this pin to the system PCIe nPERST signal. Pin Connection Guidelines
- nhadzic1 month ago
Thank you very much for the response and the confirmation about 1B bank.
I am trying to create this design on a production version of the modular board. According to the most recent version of "GTS AXI Streaming IP for PCI Express* User Guide" (9/14/2026), the production board requires only one PERST connection and the other can be used as a GPIO: "You can connect PERST# to either one of the reset pins. Assign pin_perst input port of the GTS AXI Streaming IP to the location of the reset pin connected to PERST#. For the reset pin not used for PERST#, it can be used as a generic HVIO signal."
Can you please confirm that I have to do a manual PERST# connection to the board (likely through soldering) to one of the pins listed in the original post? I would like to avoid that if there is a better way to implement the connection.
Thanks again.
- AqidAyman_Altera1 month ago
