Proper PERST# connection for FMC on Agilex5 Modular Development Kit
- 1 month ago
Whether the production Modular Development Kit already has PERST# physically routed from the PCIe edge connector to one of those HVIO pins, or whether you need a board-level modification, is a question specific to that board's schematic. I'd recommend checking the production board schematic (available from the kit webpage) to confirm whether that trace is already present before reaching for a soldering iron. If the board is used in PCIe slot mode, the nPERST line from the slot should reach the board; if it's used in tabletop/standalone mode, you may need to drive that pin from another source (e.g., an on-board logic signal or manual connection).
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responder
Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
