18 years agoProject with DE2 + cam + LCD
Hi everyone ; I work on a project with my study group of 3, it is to produce a system based DE2 the card with digital camera and LCD screen, which can detect people on the street, the problem i...
17 years agoYour question is so broad that no one will be able to give you a detailed answer here. To get started you're just going to have to get your feet wet.
1 - Visit http://www.altera.com/literature/lit-nio2.jsp and absorb as much information as you can. Specifically, there is a new Embedded design Handbook that contains a first time user's guide: http://www.altera.com/literature/hb/nios2/edh_ed_handbook.pdf 2 - Fire up SOPC builder, create a very small system with a NIOS processor, some onchip memory (for code storage and execution, and a PIO port that you can use to drive an LED on the DE2 board. Instantiate this newly designed system in your top level. 3 - Fire up the NIOS II IDE and create a software app for your new system that blinks your LED. If you get this far, you're doing great.
