Programming the Image Core: Error - quartus_cvp is not recognized as an internal command.
I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual:
quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf
The terminal presents me the following error:
'quartus_cvp' is not recognized as an internal command
or external, an operable program or a batch file.
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
- JohnT_Altera
- thanhle
Hi JohnT_Intel,
How should I perform Core Image update without installing Intel Quartus Prime ?
- SATC
ok, I will restart the PC.
- SATC
Okay john, it worked.
But now, I have another problem. The data visualization is done through / dev / Alter_cvp, right? but I can't open this file, how should I proceed?
- JohnT_Altera
The altera_cvp is used for CvP usage only. You will need to write your own driver to send the data to the PCIe end point.
- SATC
So, as I understand it from this tutorial https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_c10_cvp.pdf
the verification of cvp registers must be done through this file. How can I check the VSEC Registers of CvP status?
- SATC
John,
I believe that the users of the FPGA Cyclone 10 GX card must have already started the projects with the use of PCI, would you know to indicate me a person, question in this forum or a tutorial in pdf of the alteration that guides the development of the PCIe endpoint?
- JohnT_Altera
I would recommend you to look at the altera_cvp.c code to understand how we are using the it to access the VSEC register.
- SATC
Ok, and about the other question, Can you recommend me some material?
- JohnT_Altera
You may refer to https://www.intel.com/content/www/us/en/programmable/documentation/xtq1467072880606.html for the PCIe design example
- SATC
John, thank you very much for your attention.
Tomorrow I going to study this material and any questions, get in touch.
- JohnT_Altera
Sure. Let me know if you have any more question.
