ericmtzr
4 years agoProgramming a Cyclone III device with a different speed grade
I have a question about programming a Cyclone III device with a different speed grade than the original part. The original design targeted a P/N EP3C55U484C8N but none are available. I can get EP3C...
- 4 years ago
You are moving to a faster part, should not be a problem. The speed is not part of the programming file itself, so it should program just fine. And unless you are doing something sketchy with your design it should work just fine too.
ak6dn
4 years agoYou are moving to a faster part, should not be a problem. The speed is not part of the programming file itself, so it should program just fine. And unless you are doing something sketchy with your design it should work just fine too.
